Defiant
DSM Wiseman
- 34,745
- 228
- Jan 13, 2003
glorious Galt,
California
god, I hope mom doesn't see the pictures of those grotty things on her rug...
psssst.....got boost?Originally posted by Project ES
Does all this apply to AWD only? i got a 94 that im in the process of doing a auto n/t to man. turbo swap and i got my shifter and cables from the 91 awd i got my motor from but i got my trans from a 90
Originally posted by NOSLO2PT0
Simply put:
90 tranny in a 91-94: All you have to do is swap the lever that is bolted on the tranny and the bracket that holds the cables on the tranny. Built in short shifting tranny.
When your refering to the lever thats bolted to the tranny your talking about the vertical one that doesnt have the roll pin right?
Have you succesfully put a 90 into a 91+ if so I may ask for more help if I run into problems, but if all I have to do is switch one bolted on lever and a couple of brackets it should be cake...
Richard
91 GS-t <-- getting a 90 tranny
Az (623)
Originally posted by gravityforce
nevermind I found that the vertical levers are the same on the two 90-91-94, so I guess its time to knock out that lever held in by a roll pin, whats the easiest way to remove it ? I've been banging away at it but it hasnt budged.
Ok , drove it again this morning and found out that 4th gear doesnt want to go, real bad grind. It shifts into any other gear w/no problem, so I wonder if its just the used junk yard tranny.
Oh yeah the clutch does still slip.
Originally posted by PogiTSI
im having the Same problem, I just got done putting in a 90 tranny, in my 1992. heres my problem. I can get in 1,2,3, 4th is no go, 5th is hard, R is damn near impossible. here is what i found out just a few mins ago. It seems that The lever that moves side to side isnt keeping Tension on the up and down LEver on the tranny, Causing it to move up to high and not being able to get into 4th, and so forth. I can get into 4th if I shift real fast from 3rd. What do you think needs to be Adjusted?????
K, So When I adjust the Cables. When I go for First I shouldnt hit the Stops? and the same for 5th and R?
Originally posted by top_end95
I sort of have the same issue going on EXCEPT that the previous owner of my car (90 Eclipse GSX) only swapped out the shifter, shifter cables and brackets for those from a 91. As I understand it you also need the tranny out of a 91, correct?
To get to the point my car shifts like crap. Sometimes it goes into gear and sometimes it doesn't. Also has a real notchy feeling.
Do I need to adjust it or do I just find 90 shifter, shifter cables and brackets?
Thanks in advance.
Originally posted by Morphius
Changing out the cable bracket on the trans should fix that, along with adjusting the cables. PogiTSI has similiar issues and is trying this same fix.
