90 oil cooler lines HELP!!!
jazzyjay
216
Mar 27, 2003
I have relocated my oil cooler but need to know with port is out(To cooler). There are two port(banjo fittings) below the altenator if you look behind the drivers side tire. I need to know which is pushing oil out. Thanks in advance :dsm:
The circled line is the output from the pump that will feed the cooler..
Jeff
Thanks Bro I figured it out the hard way. I pulled both off and cranked the car.:shhh:
Jeff
is that the morroso pan or the obx?
looks hot!!!
so with the oil cooler and the morrosso, whats your oil capacity?
looks hot!!!
It's the Moroso pan. Oil changes are 7.5 qts.
Jeff
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
