Resolved 90 GSX EPROM ECU in a 90 GST?
Mits3gts
188
Sep 30, 2004
bellingham, Massachusetts
Does it matter if a AWD ECU is in a FWD car?
I have tried searching but couldn't find this answer. I can get a 90 EPROM out of a GSX, but not sure if it'll work with my 90 GST?
Thanks for the help
Solution
What matters is that it's the same transmission type and much less so FWD/AWD to start with. Once you change the chip out it doesn't matter as long as it's a '90 turbo ECU.
The 91+ people can use just about any 1G EPROM but people with '90s need to stay with '90 ECUs to avoid tach problems.
Steve
Steve
Solution
