1G 90 engine harness with 91 ecu, ptm and coil pack?
caseyk
206
4
Jul 17, 2008
Anderson, Indiana
Im close to finishing up my 4g swapped mirage.
I guess basically think of it as a 1990 talon with a 91 4g63 swap with all sensors. The 90 harness has a few different plug ins compared to the 91.
Things I have finished wiring are the tps and the cas.
Now I believe im just stuck with the power transistor module and coil pack.
Ive done research for a few hours and I havent gotten a straight answer exactly what I need to do.
If you have a 91 coil pack and power transistor you will have to rewire the '90 harness to mimic the '91 plus style. Search for converting a '90 tach setup to a '91 plus style ignition. I have done it and it wasn't very hard. If I had more time I would search for the link.
