90 Ecu
Status
Not open for further replies.
Ali Bodrick
Dec 6, 2008
orangeburg, South Carolina
Greetings to all on here,i have a 92 fwd eclipse with a 90 4g63t,im looking for a Eco eprom,for it,can anyone help me?
Do you mean an EPROM-type ECU, or a chip for in your ECU? What mods do you have?
the engine was swapped into a 92 body style eclipse from a 90,i have no mods done just need the ecu so that the car can crank up.
Use the 92 ECU and 92 sensors. The wiring harnesses are different, and that is the easiest way to do that.
What you want then is a 1991/92 ECU. Your 1992 transistor pack doesn't play well with a 1990 ECU, and the 1993/94 ECU's have more emissions stuff in them. Do you care if its an EPROM-type ECU or not?
keydiver
Status
