9-10 psi only???
babyviper
607
150
Feb 12, 2003
Mays Landing, New Jersey
Well i built my girl freind a 97 gts spyder converted auto to manual . My problem is the car will not boost past 9-10 psi !!:cry:. mods are crower 264-272 14b turbo 7cm, willy 255 pump , afpr 43.5 psi.ngk non protruding 7es plugs 3' down piple 3' exhaust test piple on, hallman bc. jeff (dsm chips) chip. Iv done a boost leak test 10:ohdamn: times compression test from timing belt side is 145psi 175psi 177psi 170psi . Iv change 14b turbo with another one samething 9-10psi ?? it has no exhaust leaks!!!!:nono: (Iv even put vice grips) yes vice grips on the wastegate flapper on the exhaust housing :sosad: The car is very slugish almost got walk by a scion tc :toobad: Please Help:confused:
Have you tried a different boost controller? The one your using could be bad. Use a boost controller you know works FOR SURE. And make sure all the vacuum lines on the wastegate, bc, and j pipe are veryy tight.
Well I found out the reason why the car wouldnt go ova 9psi. After all these tests and changing all these parts, it was the ebay downpipe. apparently the flex pipe that was only 3-4 months old, the inside of it had collapsed. Ill post pics of it soon and start a thread called ebay downpipe causing low boost.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
