only boosting like maybe 1 or 2 psi
When you say that you fixed all the boost leaks before, do you mean before you had the turbo off? If so, do another one!
Does the turbo spin freely? Did you put any rags down the IC pipes while you had the turbo off and forget about them?
WG hooked up wrong?
Any chance you over-torqued the compressor locknut on the shaft and bent it? A bent shaft will prevent boost from happening....it will also sound like a Supercharger and destroy the entire turbo if left alone.
Aside from that I'm going with some type of wastegate malfunction that is not allowing the flapper to close entirely.
try running it with your wg vac line off but remember you will not have any control... only your foot will control how much boost is made...!!!
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
