$800???
MDAdams1186
45
Nov 16, 2004
Churchville, New York
"anyway, the 14B turbo from the 1990-1994 manual transmission turbo DSMs fits onto our manifold. you can only use two bolts out of the four, but it fits, and with enough cheap tricks you could turbo that car for under $800 and make around 180-190whp, but any more then that you will have to get a real fuel system, manifold, etc."
$800 bucks for a turbo'd 420a?
It seems to me, with only using 2 out of the 4 bolts, that you would have quite a few leaks with that. I dont know if it would work. Never heard of it. Never heard of it not working either. I would stick with the known kits though.
Agree when you only have 2 of the 4 bolts that fit its going to leak quite a bit. Unless you have a trick up your sleave, i wouldn't do it.
My talon has two bolts rather then 4 cause the people who had it before me snapped two and left it but IT DOES`NT LEAK!!! Or else I would probably leak in my pants.
im willing to bet that if you remove the turbo and put it back on with just those two bolts, you will more then likly have trouble getting it to seal again.
it was an arguement about making a 420a faster in some dsm forum...i saw it and i was like what the hell i've never heard of that before...but thanks for clarrifying that...my 420a will have to get its hopes up somewhere else ROFL
