2G $8 Bolt On Coolant Reservoir
SpankyStokes
120
77
Oct 15, 2019
San Antonio, Texas
Hi, I thought I would share as this requires no drilling and 100 percent directly bolts up to our chassis for 8 dollars.
Having a FMIC I needed to get rid of my factory tank.
Part number at O'Reillys is: MCR3
The bracket it comes with is flat but I bended it to pull the tank towards the bumper so my fender liner is re attachable.
To top off the tank without a funnel you just fill up slowly at the radiator cap keeping an eye not to overfill the tank as it draws coolant.
It comes with 3 ports. 2 will need to be cut. One a flow and the other a vent.
Existing and mounting location
The clear line is terrible and kinks and will be replacing it. Also the location is low so I'm hoping I won't have any issues but have read people relocating it there without issues. Thought I'd share regardless.
I had mine there at one point (same get up) but rethought my strategy as if that thing decides to pop open or bust during a wide open pull that’s hot slippery coolant all over the front tire. Not to mention without the splash shield in place it’s vulnerable to rocks and debris getting kicked up off the tire.
