$74 ebay oil pumps?
forcefed86
1,007
14
May 23, 2006
wichita, Kansas
Looks like the BSE kit on my cover was galling up the bore is sits in. Quite a bit of side to side play and the BSE and the bore in the case are shot.
Shopping around for oil pumps and found these on Ebay.
90-92 PLYMOUTH LASER EAGLE TALON & TURBO OIL PUMP 4G63 : eBay Motors (item 330356903167 end time May-29-10 10:57:08 PDT)
Anyone using them?
Good? bad? indifferent?
I have 2 motors now. Noticed one motor has straight cut oil pump gears and the other has more on an off set angled cut, similar to a rear end pinion gear. Like so....
I'm assuming the offset cut is the aftermarket unit and the straight cut is OEM?
Which is better? Does it matter?
I'll throw up some actual pics if anyone is interested. I plan on using a BSE again, so I'm sure either oil pump will work fine.
Just making sure there are no horror stories about cheap, Chinese, Ebay knock off oil pump's.
Personally i would never take that chance i even have second thoughts about using topline farless an ebay piece.Thats just me
