Are 93-94 and 95-99 7-bolt oil-pumps interchangable?
brownfinger
1,957
11
Aug 26, 2008
Normal, Illinois
I just picked-up a new car. The engine was installed as a rebuild about 20,000 miles ago. I have the reciept. The thing is, it has low oil-pressure. There is a leak at the oil-pan, the flex pipe is broken, and the timing-belt is scary-loose. Since all those things have to come off, I may as well pull the oil-pump while I'm at it. I f I need to replace it, will a 2G pump fit the same as a 93-94?
