7 Bolt Stock..Wont Start
CC_2G_DSM
Apr 29, 2008
Corpus Christi, Texas
I want to apologize for the thread in advance. I have searched and searched..I took my head off and put it all back together and It the starter motor is running and cams are turning but it wont fire up. I took the wire off cyl 1 and attached a plug to it and when it was starting it sounded like a back fire. and it smells like gas after and plugs have a light coating of fuel. No leaks..Help? please!:mad:
:dsm:Zach:dsm:
Cam angle sensor part 8the part that bolts into the cam..not the sensor it self is missing?)
or Crank angle sesor plug not installed,mixed up with a-c plug/ Crank trigger plate not on/backwards etc.
those are some of the little things that people tend to forget while rebuilding an engine /to excited to get it running
Ive seen that happend many times before.
edit: if youve only done headwork.. is the timing up 100%ß a buddy did the same,no start, timing was off (car would start,backfire,then die)
Ok, Checked timing and its at TDC, how do make sure the Camshaft Angle Sensor is lined up? I appreciate all the help. I hate the car now.ds
DONT HATE THE CAR!!!! I had the EXACT 100% thing happen, CAS was bad, it wanted to start so bad but just didnt fire no matter what direction i had it, no matter how i had the plug order. Slapped my buddies CAS in, and BAM 2 seconds of cranking and she fired up.
I think we all come to the conclusion its a bad CAS.:thumb:
OK...Time was off. I was wrong. Tested CAS and its good. Please forgive. Second DSM..still learning. Can y'all look at these pictures and make sure it looks right please?
I forgot to mention that Intake Cam was 180 degrees off. Pin was at bottom while EXH Cam pin was at top.
:dsm:Zach:dsm:
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
