7 bolt and the 6 bolt (what are the same)
4g63turbo84
614
Dec 10, 2008
ocala, Florida
I have a 7extra bolt in my 97 gst and I just picked up a bear 6 bolt block, so I want to know what can I transfer from my 7house bolt to the 6block bolt. I know the oil/water pumps are different but what about the bolts? Can I use the water/oil pump bolts, and the also the berings bolts???
The following is a list of required 2nd gen. parts and the 1st gen. parts that were modified.
2g= 7 bolt
1g= 6 bolt
1st gen. water pump (modified) - part# xxxxx
1st gen. (6 bolt crank) engine block (modified) - part# xxxxx
2nd gen. (7 bolt crank) oil pan (modified) - part# MD332043
2nd gen. oil pump (modified) - part# MD327450
2nd gen. crank angle sensor - part# xxxxx
2nd gen. hydraulic tensioner - part# MD308587
2nd gen. motor mount (modified) - part# MD189172
2nd gen. arm, timing belt tensioner (modified) - part# MD170402
2nd gen. cover, timing belt (modified) - part# MD332865
2nd gen. cover, timing belt under (modified) - part# MD199941
you can also take a look at this link. 6 Bolt Motor Install Into a 2G Eclipse
2g= 7 bolt
1g= 6 bolt
Thats a very old outdated way of doing a 6 bolt swap.
