4G Eclipse 6G75 TIMING BELT RESET
EECKDOUG
Mar 30, 2022
Orlando, Florida
In the process of replacing the timing belt on a 2006 6G75. At this point I have replaced the Water Pump, Idler Pulley, Tensioner Pulley, and the new timing belt is in place.
I made a mistake and turned the Tensioner Pulley clock wise to torque it not counter clock wise. Subsequently, the crankshaft sprocket is not TDC and the camshaft sprockets are close but not perfect.
I have removed the new auto-tensioner and compressed the pushrod. I would please like to know what steps I should take now to get the timing belt components reset, realigned, and back to TDC without causing damage to the engine.
Thank you.
You'd be better off asking this on a 4g forum not a dsm forum, but just turn the crank enough to rotate the cams into place and spin the crank back to TDC. If you feel binding back off and adjust as needed to get things rotated into place.
Thank you very much I appreciate it.
You are correct I do feel binding. The crankshaft sprocket actually stopped.
When you say spin the crank do you mean with the crankshaft pulley bolt in place?
  • Wanted 1g Chassis harnes fuse box
    • 92AWDHX40
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
