6bolt swap into a Evo 1 (CD9A) won’t run but will start
spooliejuli
Jun 15, 2022
Sherwood Park, AB, Canada
Hey guys I need major help, I have a Evo 1 GSR I swapped a 6bolt in it but I can’t get it to idle.
I have checked over lots, thinking maybe it’s the CAS but no if I crank it 180 I can hear the fuel pump prime everything. I have 2 MAFs as well, both work and aren’t broken (maybe be aren’t the right ones?) I also rehooked up the O2 sensors and put my old exhaust back on but nothing. The car cranks and starts sometimes but won’t run.
Do I have to reset the ecu somehow?
I also know on the 6bolts they have a coolant temp and a ac temp sensor, I have nothing hooked up to the 6 bolt coolant temp sensor, is that the issue as well?
Firing order is correct, new battery, new starter, new sensors, I’m just at a loss
I’ve put the car back together over 4 years and I want it out this summer I appreciate y’all in advance!
Thanks! PFA of my pretty girl
