6bolt swap injector swap question
RogueTalonTSI
92
Feb 13, 2011
Parkersburg, West Virginia
So here is the deal. I swapped a 6bolt into my 95 tsi.
I have link v2. I can't get the car to idle well both hot and cold, its one or the other. I have enabled non-95-96 cas in link. I thought that that ment you didn't have to swap spark plug wires but on my setup I do. I remember reading somewhere that you also needed to swap a couple of the injector plugs around but I can't find that information again. I have the 1gina2g guide but I don't want to swap pins around on my ecu.
After all that I guess my question is do I need to swap my injector plugs around as well as my plug wires eventhough I have enabled non95 cas? If so who'd injector plugs need swapped? Tia
From what I read you don't really have to switch them, it's recommended for smoother idle. There is a write up from RRE. Just google 1g cas and it's the first page. At the bottom of the page it has a explanation of the wires to switch.
