650cc and cant tune at all
GSTdude06
481
11
Oct 29, 2005
Mesquite, Texas
I bought some FIC 650cc injectors and no matter what I cant tune them. The SAFC and logger arnt making sense to me. I tune short trim to 0 and long tirm to but when I tune the short trim to 0 the car doesnt run right AT ALL so I cant get to the long trim. I ended up at around -43 at 2000 rpms for it to run right but the logger said short trim was positive 8. Move the -43 down some car wouldnt run right. So im lost.....should I sell the injectors and figure whats going on? Or should I keep them and take it to a shop and pay the 150$ a hour for them to do it?
Logan
Are you sure your doing it right? My car runs just fine with 650's and an S-AFC.
Maybe you have a boost leak or the injectors aren't seated correctly? check for the little things.
I've got my car pretty lean on my low trim on the exact same injectors and the maft alone.
Well its not the tuning I found out, cause I reinstalled my 450's and I cant even go past 2000rpms......
So im bout to leak test it.
Tevenor said:
Step 0 for any problem diagnosis should ALWAYS include a leak test. Hell I do a leak test when my tire pressure is low. :D
Hey me too, I thought I was the only one. Bird shit on the window=boost leak test.
I do em everytime something is going wrong....but before I installed the injectors I did one cause your not sopose to tune with any.....so I did and found none (soapy water) well installed the injectors and something went wrong so I figured first a pipe came loose but didnt so I figured it was the injectors...changed them out still had it.....leak tested and found a leak...I blew a gasket :(
But now I got another gasket for my jpipe and no matter what it doesnt seal...i hear a high pitch noise and soapy water shows its from there.... any ideas? silicon sealant?
