cua0
- 0
- Jul 23, 2005
Lacombe,
i just bought this car, it's a 92 TSi AWD with a JDM swap (otherwise bone stock.) its got the cyclone manifold but it's not hooked up.
anyways here's the scoop, as soon as i get to 5800 or 6100 rpm the car stutters and acts like its running out of fuel. i replaced the plugs and wires and the ones i took out looked like they were running a bit lean on cyl #1 and cyl #4. so I'm pretty sure it's being starved of fuel, but I'm not sure why, all the vacuum lines seem to be in order, aside from the emissions stuff that is omitted because of the JDM components.
i was concerned that i was overboosting and leaning out because the stock components couldn't handle the added air and properly trim fuel, but i tried lugging the car into 4th and building boost from 1500rpm to redline, it built full boost and had no stutter or issue until ~6000rpm
the car has 287k kms on it and the motor supposed to have sub 100k on it. I'm wondering if anyone else has had this problem before and what fixed it if they did.
otherwise I'll end up spending a fortune replacing potentially good parts hunting a gremlin on a vehicle I'm otherwise unfamiliar with (i just picked it up this weekend)
my next step is replacing the fuel filter, and if that doesn't work I'm going to swap out my injectors with my civic because i know they work. if that doesn't solve it then I'll replace the fuel pump. beyond that I'm totally mystified as to what would be causing this otherwise very mechanically sound vehicle to fall on its face at such a high rpm.
any help would be more than appreciated
--Brent
--Brent
.. if you got any more info dont be afraid to pass it my way
im learning every day when i get on this forum
