6 bolt swap, which knock sensor to use?
WILOWNU
132
Mar 9, 2006
Wheelersburg, Ohio
Ok so i have a 6 bolt swap in my 95 tsi. The wire has been pulled out of the knock sensor so I am going to get a new one, but I dont know if I should get a 1g since it is a 6 bolt or a 2g since i am using a 2g computer. Any idea? Also, if anyone has an extra one of the one I need LMK and we can do some business. thanks.
You get the knock sensor that matches the ecu. If you are using a 2g ecu, get the 2g knock sensor, if you have a 1g ecu, get the 1g knock sensor. The engine you are using has nothing to do with whick knock sensor you use.
