ZombieSix
- 506
- 3
- Jan 29, 2012
Guam,
Asia
perfromed a 6 bolt longblock swap on my 98 gsx. everything is hooked up, everything looks solid. The power transisor keeps getting hot as #### and the car will idle like absolute shit for abotu 20 seconds. withen 20 seconds of the car turning on the car will idle at like 500 rpm, the PT will get hot as #### (burned me hot), and then the car will die. Wiring all looks pretty good. Using a green top cas with a RRE harness, white wire is spliced into the old cas wire. everything looks good. PT is connected to its bracket and bolted to the firewall, it still gets hot as ####. tried another pt, it got hot immediately once car was on (and idling like shit) so i shut it off quickly, i dont want to burn up this one. Need some help. Engine was swapped because old engine spun bearing/began knocking. Stock 6 bolt longblock, good compression.
