justinh722
- 131
- 1
- May 3, 2010
Hampton,
Iowa
I have a 95 gst that threw a rod through the block and I purchased a 6 bolt engine from a 1990 gsx. Will the flywheel from the all wheel drive tranny work in my fwd tranny? Also, it says to swap all the oil sensors and coolant sensors. I seen one coolant sensor on the 6 bolt and one other sensor that's on the temp housing that looks like a temp sensor but has 2 vacuum ports coming out of it. I swapped out the ISC and coils. It also says to use my starter plate from the 7 bolt but for some reason my motor didn't even have the starter plate.
I was also looking at a guide on tuners that said to swap the TPS's but the 2g tps is bigger round than the 1g. My 1g TPS has a harness coming out of it with the connector clipped on the end so I don't know what to do about that either. I currently have ecmlink to complete the install once i'm done. I was wondering what your guy's take would be on not running a timing belt cover. Also, the MDP sensor that was on the 2g, is it ok to just not use it or is it recommended to T-off at the brake booster? Also, I currently don't have a oil cooler for the 90 filter housing so would it be alright to just look the lines? I think that's all the questions I really have at the moment. Any takers? Thanks
