6 bolt swap questions
mitch26753
354
Aug 8, 2007
ridgelely, West Virginia
well i searched and really can't find anything. I have my motor and everything swapped over. I am doing a full 6bolt swap. WHat i need to know is that i thought as long as you swapped the plug wires that you didn't have to change the ecu pins to trigger the injectors? Is that right? I was just looking on magnus and they were saying that i have to switch the ecu pins around? I haven't started the car yet just waiting on a couple parts to come. Any help?
Doesn't anyone know this? Everyone else i have talked to about this swap, never said anything about switching the pins around? Magnus is the only site i have seen this on, i haven't looked on rre.
What I did with the swap was just switch the signal wires to the coil. There are 3 wires with one of them being black a believe, just swith the other 2 and there will be no need to swap plug wires. I found this to be the cleanest option as long as you can do a good soldering job. After I did this, the car started up on the first try :thumb:
