6 Bolt Swap Questions?!?
ECLIPSE95
430
Nov 13, 2002
Missoula, Montana
1) I spun a rod bearing and I need a new engine should I go for the 6 bolt swap or stick with the seven bolt?(but fear of crankwalking later?)
2)I've searched! but on the tech forum the links to http://www.magnusmotorsports.com/1g2g.asp doesn't work?? so Im clueless on the wiring of the cas and other things I need to do??
3)slowboy racing has a kit for the swap is kinda spendy! 2 grand and the tech forum doesn't make reference to the water line(filter to water pump) I think this should be on the six bolt engine right?
4)How much am I looking at for this swap overall vs the seven bolt?
I have a 93 gsx and i converted it to six bolt. Im not sure about the 2g. I would get an oil cooler. Other than that everything should work. I will diffently go with a sixbolt. Yes the line should be on the six bolt and its worth doing a motor sawp to a six bolt and also do a balance shaft removel
