6-bolt swap coolant sensor question
blackGSX2g
DSM Wiseman
3,334
88
Apr 30, 2004
Kalamazoo, Michigan
Alright, I've gotten the motor all assembled...basically ready to drop in except for the water neck/thermostat housing. The 1g turbo thermostat housing has 3 sensors on it, whereas my 2g one only had 2. My question is where to put them? There is one with two prongs on it that look like a 'T'...both the 1g and 2g were in relatively the same location so I just swapped them. My main question is the two bigger holes on the 1g housing. One is below the thermostat and the other is above it. Which one do I block, and which one do I put the temp sensor in? Any help or pictures are much appreciated as I am more of a visual learner. Thank you.
i really thing you can go with either or --- then you can also use the extra hole for a aftermarket temp sensor.
If i had to pick one - id say the one under the thermostat. thats were the temp will change first.
Alright, thanks. I saw your post on this where you loaded pics of it when I searched, but it was old and the pics weren't there anymore. I'll go hook those up tonight, thanks.
