6 bolt in a 97 gs-t
Initial DSM
903
Jan 30, 2003
97 Eclipse gsx, New York
hey guys i'm doing a bottom end swap cause i have four 7 bolt cranks all no good and i cant find a good uncut non spun bearing 7 bolt crank for the life of me ...i already have the 6 bolt block got the crank polished new rings main and rods bearings...i'm still gonna use the stock 2g head .. i know i have to bore out the head stud holes ..what water pipe do i use?and is a 6 bolt awd starter plate the same as a fwd starter plate? i never did this before if anyone knows of anything else i have to do let me know that will be a big help thanks :thumb:
well first off, you could search on the matter. But i will help you out a little. You are gonna have to use the 2g waterpipe, and use the starter plate from the motor that came in your car. OTher than that, use the search button, or do a google search, and you will know all you need to know.
