6-Bolt in a 2g auto trans
whiteboyz
244
Jul 21, 2009
Albany, New York
i know someone is going to say search and i have searched and the info is very limited with auto transmissions, i've called jacks transmissions i've called stm and i've called a few other places, nobody seems to know squat about this. does anyone know what parts i will need to mate a 2g auto tranny with a 1990 6 bolt? i've found the kiggly kit, is there another one not as expensive or can anyone tell me what other parts i'll need besides that? the engine is being fully rebuilt.
this is going in a 99 gst auto
There is something different you have to use? News to me. We installed a 6-bolt into a 92 Summit wagon. The transmission we used is from an RVR (turbo model) from Japan. The transmission is a 2g transmission. We just used the 1g/6-bolt flex plate with it. Little wagon is running low 13's on a T-28. No transmission issues.
the kit that kiggly sells is specifically for the 6-bolt in a 2g car. The 2g W4A33 transmission has a lock-up torque converter so the transmission is different from the W4A33 found in the RVR's. FWIW i run an RVR in my 1g talon, no kit was needed.
The reason the rvr trans works is because it's not a 2g transmission. It's a 1g type transmission with 2g mounts. The converter is not a lock up, like the 2g trans. If you try to bolt a lock up converter trans to a 7bolt, with stock hardware, the converter tries to go to far into the trans, and damages the pump.
Buy the Kiggly parts and be done with it. Everything will work correctly with the kit. The reason this kit is needed is without it you will damage the Transmission pump due to having the incorrect torque converter spacing.
The Kiggly flexplate is also a beefy piece as well. Kevin is a great guy to deal with and I stand by his products to the fullest!
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
