6 bolt engine rebuild question
Engineblow1
Aug 21, 2004
Spartanburg, South Carolina
Found metal shavings in the bottom of the oil pan in my friends eclipse, so I'm helping it tear it down now. Is the crank gear (the gear the timing belt runs on) pressed on the crank and do you need a special puller to remove it? Thanks for the help.
