6 Bolt engine in a 2G car
The best method is obviously the one that makes it work. :D
"Best" is too much of a subjective word, so start reading and determine which is best for you.
6 Bolt Motor Install Into a 2G Eclipse version 1
6 Bolt Motor Install Into a 2G Eclipse version 2
RRE CAS Instructions
http://magnusmotorsports.com/wp-content/uploads/2010/02/1gina2g.pdf
http://www.dsmtuners.com/forums/bolt-tech/156537-hyundai-front-cover-6-bolt-2g-crank-angle-sensor.html
The search function will help you figure out anything you need to know about this swap away from these links. This subject has been beaten to death, so the information is out there.
