6 bolt in a 2g
almst 92 tsi
69
Dec 5, 2008
Bremerton, Washington
Im putting a 6 bolt block with a 2g head in my 95 gst. I was wondering if i have to use the 6 bolt timing belt tensioner and the pulleys or will the orig 7 bolt stuff work? Alsowill a timing belt from either generation work?
All timing belts for the 4g63 are the same. The tensioner has to be from a 6 bolt though and the water pump has to be from a 6 bolt. Basically you want everything under the head to be from a 6 bolt and everything from the head up to be 7 bolt. You're also gonna have to manually place the tension on the timing belt with a 6 bolt bottom end\7 bolt head combo.
what do u mean manually set the timing belt tension?
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
