6 Bolt in a 2G AWD
LaserRSTAWD
Apr 27, 2006
Kokomo, Indiana
I just bought a 2g awd, it is apparently set up for a 1G. It came with a 3" down pipe, what is the difference between the one for the 1G awd downpipe and the one for the 2G awd? I also had another question, which can prob be found elsewhere, but which clutch should I buy? (300 Hp ish for now)
the downpipe is car spacific not motor -
if its a 2g -- the the downpipe should be from a 2g. (all tho a modded 1g should work)
clutch ? id go with a spec stage 2 myself.. i loved the one i had. DEATH to ACT imho.
Specs are hit or miss, so you have to be careful, they also tend to chatter. As far as exhaust, hes right, it is car specific, the only way I could see a 2G being setup for a 6 bolt motor is if the motor mounts were different, but seeing as the car already has a 7 bolt motor in it then its not setup for a 6 bolt.
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
