6 Bolt block identification
Gerg
124
4
Dec 19, 2012
Cheyenne, Wyoming
I recently got a block machined but as I was looking it over I noticed its not a turbo block. I also noticed that the main caps are different, where is the turbo version has "suitcase handles".
It's not a DSM 6-bolt, all of which had the same main caps. Could very well be a Galant SOHC 4G63 which had the individual mains, but the easiest thing to do here is check the VIN.
Okay I took a few pictures. And where can I look up the vin for these motors?
Look at this location on the block and either post it or try decoding it with this: Decoding VINs.
Example:
It looks like mine was taken off. And a picture of the head that I forgot.
Well that's unfortunate. I would love to see more pictures of the different sides of the block.
As I stated, my best guess is a SOHC 4G63 from a Galant.
Here's some more pictures.
BBCBB?
There has got to be some number on there that will point you in the right direction and if not then you might just have to go get different block that you know for a fact is what your looking for.
I've checked the entire block for clues to what the vin might be. But It's not like im looking for a certain block in perticular so I don't see the point in getting another one. I'm just curious to what this block came out of.
They did not. :)
Anyway, whatever it is from, I wouldn't hesitate to use it.
Well thanks for the reassurance! I should be starting to put it together here soon, I just need to pick up a few tools and new dowel pins. I've already got wiseco pistons, eagle rods, and acl bearings. Hopefully with the help of my factory service manual and the community it will come together fairly smooth.
And now that I have a super JDM block I can compete with the horde of subarus in my town. LOL
Don't get carried away. No one said it was JDM. ;)
Just curious and it may not mean anything, but did the head come with and attached to the block?
Looking at the main caps, it looks like a hyundai sonata block from the mid 90's. They used a sohc and a dohc 2.0 in those cars with those style main caps.
Haha ya I was just kidding, all the subaru owners here talk about how they have jdm this and that. But yes the head came attached to the block, it was in my 91 AWD that I decided to take apart.
Well thanks for your help, any disadvantage to running this block opposed to a 6 bolt out of an eclipse?
Not really. I can't see the 2 bridges on the normal 6 bolt main cap adding a ton of stability to the bottom end. If you want to make a lot of power than i would consider a main girdle. The upside to the main caps being separate is that it will cost a bit less to have it line bored if it needs to be done.
I'm planning around 500hp, I already had all the machine work done it's just a matter of me putting it together. But thank you for your help! :thumb:
You should be fine at that power level. One thing on these engines that i have yet to see let go is a main cap. They are pretty stout in the bottom end.
I do believe that even the NA eclipse blocks have different main caps. I think that bryanwheat is correct that it is out of an sonata.
