6 Bolt block identification
Gerg
124
4
Dec 19, 2012
Cheyenne, Wyoming
I recently got a block machined but as I was looking it over I noticed its not a turbo block. I also noticed that the main caps are different, where is the turbo version has "suitcase handles".
I do believe that even the NA eclipse blocks have different main caps. I think that bryanwheat is correct that it is out of an sonata.
Correct, the na 6 bolt dsm blocks have the same main caps as the turbo block, the only difference between the turbo and non turbo blocks is that the turbo block has the oil squirter holes drilled and tapped.
  • Wanted 6 bolt NT water pipe
    • chrisman287
