6 bolt 4g64 crank in g4cs block
evo9mrtt
43
Apr 15, 2008
Arvada, Colorado
So I'm planning a build over the winter for my 1992 awd auto talon. I have a g4cs block, and a .010 machined 6 bolt 4g64 crank. Was just curious if anyone has ran this combo before? Not looking for extreme power numbers. Will be running a gtx4088r turbo. What rods/pistons etc...fuEl will be fic 2150's, dual 044's, tuning with ecmlink. Any info or tips are greatly appreciated!
well, IIRC... a 6 bolt, 100mm stroke, 4g64 crank, is a G4CS crank. those were the only motors i know of that came with a 6 bolt 100mm crank.
should be fine AFAIK. depending on your budget and power goals, you could go with eagle rods/JE-wiseco pistons (believe they have those combo kits for the 4g64/g4cs) or you could go long-rod 2.4 and use CP pistons/pauter rods...your options are endless, just limited by pocket-book.
with that kinda fuel setup, are you running e85/e100?
The g4cs is the Hyundai produced by license from Mitsubishi 4g64, and is a 6 bolt 100mm stroke engine. Mitsubishi produced a 6 bolt 4g64 in the 92 expo, and for years made an engine called the g64b, with the same 100mm 6-bolt crankshaft.
