rdrkt
- 1,540
- 3
- Apr 20, 2002
Baltimore,
Maryland
Well I FINALLY made it to the dyno. There is a semi local shop Xotic Motorsports that has a AWD Dyno Jet and they had a 5 passes for 50 bucks dyno event. I drove to the dyno 85 miles round trip in this cold ass weather with no issues other that trying to avoid the Amish in their buggies. I was on the same settings that I had back at the Shootout. I havent changed anything since Wes first built and tuned the car last spring other than the headgasket after some aggressive toning at the track last November.
All passes were made on C16 at 22 degrees total timing and 11.0afr as read by my tech edge wideband and the tail pipe wide band that the shop uses.[
The first run was at 25lbs just so I could see what all was going on and make sure all was well. All I did was pull on to the dyno after waiting my turn and I put in fresh br7es. I was a bit nervous because I had no idea what it would really make. You can see the run here
We then crept the boost up a bit every pass. I wanted to make a run at 32lbs but all we got was 29-30. My final pass can be viewed here
I should have video of the run up by next week. You can read my mods by following the link in my profile.
If I had to say anything about the passes I would say that I am pretty happy with the curve. I wish I would have been less of a ####y and run it out to 8k because it looks like the power wasnt really falling off any just staying nice and flat. I might have had another 5-7 hundred rpms there. Looking over everything I think the potential for 600 is pretty obvious with some more fine tuning and those 2 extra lbs of boost
Nice numbers. How much does your car weigh? 130 mph traps and 550 whp seems a little bit off cause you have a nice powerband too. Looking at people like Leon Reitman's 490 whp was able to net him 130+ mph traps.... Don't get me wrong, your numbers are nice, but you sure you were pretty much around this power level when you ran 130 mph traps?
you could always run your car on both and decide for yourself? seeing as you dont seem to care about what I have to say
