5 speed to 4 speed swap?
NeedTalonNow
70
3
Dec 13, 2012
Madison, New Hampshire
Please don't hate, but I may have the chance to pick up a 95 Talon Tsi with a bad 5 speed which needs replace or rebuild. Can anyone tell me what might be involved work and money wise to turn it into a 4 speed auto. Have not seen it yet, but I know the tranny is bad. Again, please don't hate.
trans, transfer case, driveshaft most likely, rear diff, tcu or shift box/kiggly mod, etc.
Would be by far best to start with a auto awd parts car if that is your choice. I love my auto awd, no hate here. I had planned to 5 speed swap and needing EVERYTHING turned me off. Slowly I grew to love this auto and here I plan to stay.
If your 4spd auto to the grave set , then the best bet is to buy a wrecked auto trans car, then take what you need from it to convert it over.
believe me when I say you will waste a ton of money, in gas , trips to and from wrecking yards, friends houses, dsm tuners classifieds, shipping costs on parts etc otherwise.
I don't mean to blow your dream out of the sky or anything, I just have seen many projects go no where fast when they don't have all the parts on the table at once thats all.
Driveshaft is the same, depends on what kind of rear end is with your auto trans to decide if you need the LSD or non LSD rear axles. I definitely recommend a shiftbox over the tcu. Definitely no hate for going auto. I was auto, swapped to 5 speed, and just swapped back to auto for this season. Also axles are different up front as well
If you have a 6 bolt in your 2g then you'll also need kigglys 6 bolt in a 2g adapter because the 5 speed tranny fits, but the 6 bolt destroys the trans pump without that adapter giving it enough clearance
  • For sale 4G63 Motegi Traklite Wheels & Tires
    Motegi Tracklite Wheels & Tires $650 17X8 5X114.3 Offset +45 2 Toyo Proxes 235/45R17 Tires 2...
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
