5 speed swap
just5_0
72
Feb 8, 2013
rogersville, Tennessee
I have a silly question i bought a 98 gst and it was originally a 5 speed car and someone put a auto in it, it still has the pedals and master cyc in it the question i have is when i switch it back to 5 speed can i use the axles that's in it or are they a different spline? Thank's
Ok thank's. Do i have to change the computer and wiring harness when i change it back?Thank's
Cool so all i need is the 5 speed, flywheel,clutch fork, shifter linkage,and clutch, pressure plate, throw out bearing and the clutch slave cylinder? I really appreciate all of you guy's help, i converted a mustang i had one time over from automatic wasn't to bad juss wasn't sure about a eclipse. .
Thank's again
