4G64 Spyder GS Hybrid Evo VIII T
GsEvoVIIITSpyderMan
Apr 11, 2025
greensboro, North Carolina
I been doing my homework on the type build i want to go into the past 3 maybe 4 years i thing i have everything that i need minus some few small things for my 4g64 x 4g63 hybrid. i went to the little small mom and pop yard and came across a 4g63 head but the car it was on the belts are standing in front of the car was to the left and the belts on my 99 eclipse gs is on the right. can i still use this head as long as all the cams are set as they should be between intake and exhaust?
Update on the head issue so i went back to that same yard and found a 1G eclipse hiding of the edge of a row of cars the weeds literally took it over gold mine has everything i need in one spot with the right head on it and everything. so i will take and have it cleaned up and machined and coated again. Best part they are willing to just do the swap out.
finally got the new head all cleaned up and first round of powder coating ill keep you guys you updated as i go
I dont know if you guys can tell but on this valve cover the timing marks arent on it is the a piece missing from the cover? didnt even see any marks on the gear cover
The head/valve cover mating surface is the mark. Line the marks up on the two cam sprockets so that they meet in the middle and also line up with the surface the valve cover sits on. The camshaft dowel pins in the gears should be pointing straight up.
I appreciate that very helpful and didn't take long to get the answer guess u are the Wiseman for a reason
Just a little dry fitting to see what it looks like together everything cleaned and ready for reassembling
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
