shelbygoat57
- 3
- Dec 10, 2024
Seale,
Alabama
1997 Eclipse Spyder 2.4L
Car was running, had an exhaust leak. Installed new exhaust and cat. Now I am getting no fuel. I am getting spark. Spray starter fluid into the intake and it fires right up.
I do not hear anything from the fuel pump when I turn the key and it just keep cranking over. Took off the fuel return line and cranked it, no fuel coming out.
Which one is the fuel pump drive connector I use to put power to the fuel pump? I have the Chilton manual, but it’s not very clear.
I check all fuses under the hood and fuses under the drivers side dash on the left side, all are intact. Is there something I’m missing to check?
I’ll go down in the morning and try that, but if that doesn’t work, symptoms are pointing to a new fuel pump.
