4g64 cam angle sensor question(pics)
Jaydsm-
48
Nov 8, 2013
Aruba(Island), Central America
I did a swap on my 96 Spyder because i blew a hg i swapped to another 4g64 but the cam angle sensor plugs are different..didnt notice that until i put the engine in.
This is the 98 cam angle sensor
This is the 96
The engine that i put in is a 98 4g64 sohc and i had a 96 4g64
I tried to rewire the plugs but it runs very badly..
Any solution to this other than changing the cylinder head to the 1996 head?
JNZ Tuning has access to many of the connectors, as long as it is JUST an issue of the connector.
I could tell you off the top of my head if they have access to that connector, but can't tell anything from that pic, it is too blurry.
Sorry I cant find any other example, my car is at a friends garage and im at home so i cant take a picture of the real one..
On the jnz tuning website they have a specified cam angle sensor for 97+ Not for my 96 Spyder which concludes that they are different
The issue is that the 96 CAS is not the same as the 97-99 CAS
I tried swapping the CAS but it doesnt align to the 97-99 cams..
I also tried rewiring to the pins and the car doesnt run right, maybe the firing order has to be changed with it??
Options are:
Swapping cams
OR swapping cyl head(which is what I do not want to do)
Any other alternatives??
