6 bolt with crank angle sensor
pjules
Nov 20, 2002
Norcross,
Guys for some time now I knew that the hyundai sonata's has 4g63 NA motors in them but never checked the oil pump for a crank sensor. I have been hearing rumours of a 6 bolt 4g63 motor with crank angle sensor for a while, and did not beleived it until a few weeks ago. I have seen a few hyundai sonata's that has the crank angle sensor. I bought the block from one of these cars because the motor is a 4g63 NA motor, and fitted it with the turbo pistons and rods. I have completed the swap with the crank sensor and the car runs perfect. Of course you would have to do the swap with a 2g head, or machine the 1g cam shaft to use the 2g cam sensor, any question feel free to ask. With this no random misfire, or emission issues.
ther is a way to use the 4g63t 7bolt front case witch has the crank sensor., and bolt it to the 6bolt with miner milling of the oil ways.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
