Jays99Spyder
5+ Year Contributor
- 167
- 59
- Feb 22, 2020
Waukegan,
Illinois
Just making sure before I f#€% some $#!t up
I'm going to attempt to start my car that has been sitting for 7 years..ish
. I'm going to attempt to start it/ diagnose non startup and want make sure I have everything is in place before I do
. I'm for sure thinking pour oil or some other kind of lube in the cylinders and turn the crank over a few times. I'm worried about the gas, the tank was low so I'm going to fill it up with 97, will I be ok? Is there anything else to libe/prep. It's a 6 bolt swap 97 manual trans in a 99 spyder gs auto using a 95 ecu on a chopped 4g64 wiring harness
. All belts and tensioner was replace when swap was done. So that being said taking advice!
