Lancerboi
- 0
- Jun 27, 2012
Canberra,
Australia
You guys really know your stuff time for a different type of question,
I have a fully worked 4g63T from evo 2 (awd) in a 90" CB Lancer which i am wrecking because of engineering rules in Australia SUCK, what I want to know is can i put the 4g63t into a 2001 MITSUBISHI EXPRESS WA WALK-THRU as this van runs the 4g64aa 2.4 engine north/south mount, will the gearbox be the same and starter motor, flywheel ? and if that can bolt up I'm wondering if the standard box will handle the extra power...
from what I read the blocks are the same (except the deck height) so everything should bolt up are the engine mount points/bolt holes in the same place ?
I know i could put the 4g63t head on the 4g64 block but the rods/ pistons would not handle the boost the engine currently runs a GT30/40 turbo on 18psi link to my current build
CB lancer EVO II - 4GTuner
Now i know people will ask WHY? but i need a van for work now and the engine/turbo/ECU is just sitting there unused, plus can you imagine the looks I would get in a van that can pull 12secs or under ?
Peter.
Peter.
