4g63t into 95 toyota tacoma
2ez
Apr 15, 2011
FT Lauderdale, Florida
Hello everyone! I'm trying to install a 4G63turbo engine into my single cab toyota tacoma, i already had the monts made, im not sure what transmission to use with the engine for a rwd conversion, the engine came out of my 1991 eclipse gst, any advice?? what transmission and where could i get it from??
They make mounting plates for most modern transmissions. I've seen several t-56 transmissions bolted to 4g63's. So you are wanting to go rwd?
I have a 95 toyota pickup with a small block mopar and automatic installed. It is a prerunner project, but still a long ways away. I have a 87 supra motor, that I was going to put in, but the supra and the v8 weighed the same and the V8 is easier to get good cheap HP out of it. The V8's a tough fit though. I think the 4g63t will make the pickup fly. Good luck.
thanks, i new to this but i will try my best to take pictures and have them posted... you said i could use the T-56? what did that transmission come out of and where could i find it??
yes im going rwd... should be alot of fun
i would go with the mighty max but i already have the tacoma sitting at the shop, that's why im just going to use it...
