4g63 ac delete help
Yes there is absolutely no ac in the car what so ever. No pulley for it nothing I totally removed it and the tensioner for it is gone as well
It didn’t work at all plus the pulley was making noise so I just said the hell with it and removed it plus figured a little weight reduction
I’m not sure on how different 1g and 2g are, but if you remove the compressor and the tensioner, you should be done as far as pulleys and belts are concerned. You can also delete the condenser by the radiator and all the lines in the bay, as time allows. Then you simply have a switch in the cabin that serves no function any longer. You could wire it for guided missiles, nitrous, or a super bass amp, but that will take more custom work.
I mounted my Hallman pro MBC in place on the a/c switch...
Okay ty so much for your advice I wasn’t sure and am quite the newbie but my build is coming along very nice :) just ordered a 20g turbo today and 1200cc injectors and already have 255 fuel pump and fuel pressure regulator
