420a turbo gaskets?
should i use gaskets between the wastegate/manifold, and turbo/manifold, if so which type of metal?
Yes, with any metal on metal contact, you should being using a gasket. The gasket material varies but usually its aluminum in this case. The WG should have come with a gasket and depending on the turbo exhaust housing you have, will depend on what gasket you need. If you have a T3/T4 turbo, then thats the gasket you use. Any vendor on this website will be able to provide you with the correct gasket you are looking for.
I recommend ExtremePsi in this case. They have usually anything you want in stock and ship quick are the cheapest for most aftermarket parts and acc. like this.
James :laser::talon:
