Resolved 420A New oil pump does not have a timing arrow.
Harleyoi
8
Jul 22, 2023
Phoenix, Arizona
Just got my 420 a block back from the shop. However the oil pump I got does not have the timming arrow. I do not have the old pump for reference. How screewd am I? Is it possible to judge where the arrow should be from the Haynes manual? Thank you for your help.
yup, that's your arrow, and you put engine in TDC on #1 cyl, looks like your oil pump don't have a arrow to match but it's one tooth past 12 o'clock, your best bet is to put #1 cylinder to TDC and make your mark with the tooth which has the arrow on it. here's reference picture... or you can just buy a pump which has the mark but as long you have your engine in TDC, you should be good
You rock, thank you for your response, and the picture for reference. 🤜🤜
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
  • Wanted 2g Finish My Project!
    I am in need of some big ticket items in order to finish my project. In my engine bay there is...
    • dhssoccer24
