420a Eclipse, Wont crank or start.
g4ebguy90
2,001
3
Mar 9, 2011
Rockford, Illinois
Hi, I have a 1995 420a Eclipse. Car has been running pretty good.
Today I pulled up to a stop sign, Put it in first , let the clutch out, started to pull away, and then the car jumped forward and just died. Wont CRANK wont START. Nothing.
Timing belt is good, and A ok, Starter was replaced just 2 weeks ago.
I got 3 DSm's down right now, and me and my gf got nothing to drive :(.
Anybody have a experience like this.
If I put the car in 1st and let it roll, the cams turn.
I know not one thing about 420's...
Update, Ign. Fuse keeps blowing, but Seems to be traced to the little connecter to the starter??? I wiggled it and the car started right up,
Is the connector loose or tight? I assume it is loose if you were able to wiggle it. Make sure it has good connection. I would fix this asap so you don't continue having these problems.
i know its different motors (from the 4g63) but i was having troubles with the cable connected to the started.. tried tightening it down because it seemed a little loose. I ended up replacing the whole wire and was good to go. hopefully everything turns out for ya..
i like the fact that you have 3 dsms but none running... get them all going haha
I think you have already found your issue, when it comes loose it probably shorts or something. Fix/replace as needed and go from there.
I Just re did the wiring job on that wire to the starter, with thicker cable and new connections. She's been good ever since. I forgot to update this.
I just didn't think anything on the starter would make a car die though. But yeh it shorts, blows fuse, car stops.
As for the other 2. Rod knock, Waiting for tensioner on built engine. :)
They will be moving soon enough and O man.
Vrooommmmm pppsssshhhhhhhhhhttttttttt
Nice to see you go the spirit to carry on bro, you gotta love DSM's to have them, those that sell'em, don't really love'em like they say they do. :)
It's mostly because my next door neighbor rides his motocycle around like its something else *old ugly thing*. My one talons *1g* been under a tarp for a year with my built engine in the basement, waiting to be dropped in.
My nice looking eclipse 1g rod knocked 5th day of ownership, but I let that turbo spool evertime I passed his house LOL. Can't wait to be doing it again. Especially when his daughters out ;).
The 2g eclipse is just horrible....I let the gf drive that 420gay.
