420a cams?? what do you recommend?
Jordan, Can I make the suggestion you check out 2GNT.com upgrade path for a 2GNT? Especially since you are already in there there are definitely other things you should look at. There are also other things you should look at it seems according to the upgrades you have listed in your profile.
2GNT.com - Power_Stages
thanks this has really been alot of help:hellyeah:
after doing some researching on the 2gnt website, i see that itd be better for my car to do the stage 1 or mild cams that way i can leave the stock valve springs. but, i still havent found information on if i get the stage 2 cams, if i will need to upgrade the valve springs. any help??
@dsmak - It depends on what you are doing in your build, however this is a thread on cams and for N/T info I would strongly recommend checking out 2GNT.com.
i am contemplating between the crower 264/264 and the 272/272. its my daily driver. what do you guys recommend?
Better show linky.
I would recommend the Crower 2's NA. I have run these with stock springs on multiple set-ups. As a matter of fact, I'm running them right now on my daily.
MB
I've ran Crower 2's on stock springs forever, but had random misfires at idles and seomtimes WOT, no damage or anything, did it like that for about a year, only way I solved the misfires were for upgrading a spring and retainers set.
