40mm wastegate on 38mm flange??
interex
1,039
Apr 28, 2008
Centralia, Illinois
My exhaust manifold says it is set up for a 38mm wastegate but I was curuious if a 40mm wastegate will fit on it if I bore/hone out where the flange is on the manifold... If that makes sense.
The flanges are different.
Here's the 40mm
Here's the 38mm
Let me re-phrase... I want to know if porting my 2 bolt 38mm wastegate flange on my exhaust manifold .080" will allow me to use a 2 bolt 40mm wastegate
If something like this is what you mean... 38mm to 44mm Wastegate Adapter ...I could just make it but I was looking at a 40mm 2bolt that I found googling. I don't remember the brand now as this was this morning but it said it was a 40mm 2 bolt flange but I'm thinking now it might have been a 38mm flange with a 40mm diaphragm. I'll look more into it later.
