1G 3g brake master and booster in a 1g parts help
SasaniFab
2,432
788
Dec 1, 2013
Mexico, Connecticut
I have been searching and haven't found anything concrete. I think I fount the correct parts. I'm looking at the beck/arnley mr473975 non abs for the Master cylinder and the cardone 532731 for the booster? Is this correct for a 1g non abs car?
Brake from any booster 3g eclipse. Master for the 93 talon factor unit or after market should work. Your changing the brake booster right.
The car is a 92 tsi non abs car, I thought I get a 3G master cylinder and brake booster. I'm confused now
I'm getting the parts from a friend all together so ill have master I remember I have to change the lines so I'll be using the master off the 3g car I'm assuming both would work.
3g MBC and booster on my 92 here. Converted to non abs as well. Just had to re-bend the lines for the 3g and re-flare them to a bubble flare style to prevent leaks. There are some adapters out there but I'm not a fan and re-flaring lines isn't too hard
Yah I ordered everything from rock auto, I have the eastwood brake flaring tool so making new lines is a cake walk.
